CARVER site! Mobile
  Featured System
Carver audio forum, free Carver manuals, Carver audio information, Carver audio repair, Carver specifications, Carver modification, Carver upgrade, Carver amplifiers, Carver amplifier, Carver amp, Carver home audio, Carver hifiNow Playing
Now Playing: The Flaming Lips, Stardeath and White dwarfs, with Henry Rollins and Peaches "doing "the dark side of the moon""
Welcome Guest! To enable all features please Login or Register.
Notification
Icon
Error
11 Pages«<7891011>
CarverFest Tube Amplifiers
weitrhinoOffline
#79 Posted: Sunday, February 26, 2012 3:44:34 PM(UTC)
Send to facebookSend to DelisciousSend to StumbleuponDigg thisSend by emailSend to Addthis
weitrhino
Medals:
Senior: Black Pearl device for multiple award; senior memberModerator: -Cee-Bang!: donated to fund CARVER site! hosting
Featured: systemCarver modified: Carver mk II, or self-modified owner
Rank: TO-247L Member
Groups: Search Party, Administration, Moderator
Was thanked: 178 time(s) in 160 post(s)
Gave Thanks: 213 times
TNRabbit;87571 wrote:
No, but burned my fingers black~
  • Yikes
Gary
Vitamin E.  Nuff said.
Main System:180 Tube Monoblocks, ALS Plats, Oppo BDP-93, TD-1400,
TX-11b, Sunfire Classic Vacuum Tube Preamp, C-9, Dual CS 505-1
Bedroom System: M500t, DTL-200, C-16, TX-11a
In Reserve: Sunfire Ultimate Receiver, M500 MkII, AV-634 (2), TD-1440
Blue Mouth Promotions LLC Where the music matters most!
TNRabbitOffline
#82 Posted: Thursday, March 01, 2012 3:00:05 PM(UTC)
TNRabbit
Medals:
Senior: Black Pearl device for multiple award; senior memberFeatured: systemMusic: extensive, varied collection
Rank: TO-247 Member
Groups: Member
Was thanked: 226 time(s) in 174 post(s)
Gave Thanks: 90 times
Crap.  Amp #3 now blows the mains fuse every time I apply power to it.
Buzz is still there on #4 when they're both plugged in.  No closer than I was before, but now I have a DOA amp.
TNRabbit
My 5.1 & 2 Channel System:
Sunfire Theater Grand-IV Processor
Sunfire Cinema Grand Signature 400~7 Amplifier
Carver SD/A-360 CDP
Benchmark DAC-1 Digital-to-Analog Converter
Sony Multi-Disc Player (SACD/DVD-A)
Active bi-amping via Ashly crossover & 2 Rane PEQ-15 Parametric EQs
Carver AL-III Main Speakers
Sunfire CRS-3C Center Speaker
Sunfire CRS-3 Surround Speakers
Klipsch RT-12d Subwoofer
"elgrau" wrote:
"You're a freak'in genius Herr Rabbit!"
"martin1970" wrote:
"Left to his own devices, Bob would probably build something that looked like a turd and sounded like the breath of angels."
mbskeamOffline
#83 Posted: Thursday, March 01, 2012 8:54:50 PM(UTC)
mbskeam
Rank: TO-126 Member
Groups: Member
Was thanked: 42 time(s) in 31 post(s)
Gave Thanks: 22 times
would a bad CAP do this????
maybe one of the 2 big caps is bad?
or one of the 600v 0.1uf caps
I think I read this some place, more likely to happen on the old stuff. but now that I read what your #3 amp is doing, it came to mind
you could also try the DIY site.
when the problem is found it will most likely be a moment....
mbskeam
http://s9.photobucket.com/albums/a96/mbskeam/
I look to the sun,... yet I feel not it's warmth
Sie werden meine Flutwelle, I werden Ihre Sandkorn
#1 BLACK BEAUTY's made by the man, the myth, the legend Bob Carver
CARVER: TFM-75, TFM-45(3), SD/A-490T
SUNFIRE: Tube pre
2 sets of ALS'3, set of SILVERS, set of PLATS
AUDIOCONTROL: phase coupled activator
KENWOOD: BASIC M2a (2)
TNRabbitOffline
#84 Posted: Thursday, March 01, 2012 11:03:19 PM(UTC)
TNRabbit
Medals:
Rank: TO-247 Member
Groups: Member
Bob's reply to an email asking for assistance:
Sent: Thursday, March 1, 2012 4:20 PM
Subject: Re: Need help with CarverFest amplifiers, Please!!
Hi Gary, wow, trouble in river city!
First thing is get some good output tubes. The Electro Harmonix are great and have a nice high voltage rating.
Then replace the DC restorer 1n4148 diodes with 1n4004 units. Replace the 15 volt zener with two 5 watt units hooked in parallel. Amp should work then. As for blowing fuses immediately, check the power supply diodes for a short. Use a simple VTVM and just measure them in-circuit. If one shows a dead short, replace it. As for the hum unit, it sounds as if the AC line is somehow connected wrong. Just inspect it careful and I'm sure you will find the problem just by looking hard with your eyeballs. Be careful, because right now I think you may have a severe shock hazard on your hands with this amp until you find the trouble.
If all else fails, send them to me. I'll fix 'em right up!
No sweat,
Bob Carver
TNRabbit
Carver SD/A-360 CDP
zumbiniOffline
#85 Posted: Thursday, March 01, 2012 11:33:10 PM(UTC)
zumbini
Medals:
Moderator: -Site Builder: Black Pearl device for multiple award; major contributor to the Carver site! community.Cee-Bang!: donated to fund CARVER site! hosting
Featured: systemBill D modified: audio equipment ownerDIY: master builder
Tunesmith: master sleuthMusic: extensive, varied collectionGreeter: pearl device
Rank: MT-200 Member
Groups: Master Tunesmith, Administration, Moderator
Was thanked: 601 time(s) in 514 post(s)
Gave Thanks: 619 times
When in doubt go to the source. Hope his advice is helpful.
Main System
Carver Gear: C-11 (BillD-modified, w/balanced outs), M-500 (refit by BillD), M-500t(x2) (refit by BillD), M-1.0t (MKII/opt002 by russkall), SD/A 490t, TX-8R
Other Electronics: Behringer Super-X Pro CX3400, Behringer Ultragraph FBQ3102, Furman PS-8R-II, Nikko NPS-1, Teac C-3RX, Technics SL-D303
Speakers: Legacy Audio Custom Super Satellites (new drivers and biamp-able XOs 2010), Legacy Audio Custom Subwoofers (reconed 2010)
Office System: C-2 (modified by BillD, w/balanced outs), DTL-50, M-200t, Musical Fidelity X-10D, TX-2, Design Acoustics DA-30 (DA-20LF sub w/DA-10 satellites, reconed 2000)
Workshop System: MXR-130 Receiver, DTL-50 CDP, Design Acoustics DA-30 (DA-20LF sub w/DA-10 satellites, reconed in 2010)
Son's System: CT-Seven, DTL-200 MKII, M-1.5t (DIY recap 2011), Hitachi PS-38 (TT), Klipsch KG2.5 speakers, PSB Century Subsonic 2i powered sub
Band PA System: Aphex 124A, Behringer PMP3000 and DCX2496, Carver PM-1200(x3) and PT2400, Seismic Audio FL-155P(mains)/PWS-15(fill)/SA-15(monitors), DIY 18" Subwoofers (in progress)
Not In Use or Need Repair: Denon DCM-35 (CDC), Teac X10R (RTR), Technics SL-1200 (TT), Yamaha CDX-820 (CDP)
weitrhino wrote:
oldtexasdogOffline
#86 Posted: Friday, March 02, 2012 1:53:10 AM(UTC)
oldtexasdog
Medals:
Site Builder: major contributor to the Carver site! community.Cee-Bang!: donated to fund CARVER site! hostingFeatured: system
Carver modified: Carver mk II, or self-modified ownerBill D modified: audio equipment ownerDIY: master builder
Rank: TO-264 Member
Groups: Member
Was thanked: 99 time(s) in 92 post(s)
Gave Thanks: 82 times
I had one that blew the fuse everytime I ran the Varex up to 120v. Turned  out to be a bad coupling cap.
There are two holes in Daddy's head where all the money goes.
mbskeamOffline
#87 Posted: Friday, March 02, 2012 4:15:08 AM(UTC)
mbskeam
Rank: TO-126 Member
Groups: Member
for Rabbit...
on the bias circuit you need 2 of these....1N5352B    15V 5watt zener
what do you have in there now?
what do you have on the High voltage side of things?
stock diodes are  1N5399
mbskeam
SUNFIRE: Tube pre
TNRabbitOffline
#88 Posted: Friday, March 02, 2012 4:04:46 PM(UTC)
TNRabbit
Medals:
Rank: TO-247 Member
Groups: Member
mbskeam;88019 wrote:
for Rabbit...
The DC restorer is the same you helped me with earlier in this thread; 15 volt/5 watt.
The rectifier diodes on the xformer output are upgraded models based on advice from Mark (radioeng):  http://parts.digikey.com...-do-201ad-mur4100eg.html
Technical/Catalog InformationMUR4100EG
VendorON Semiconductor
CategoryDiscrete Semiconductor Products
Diode Type Standard
Voltage - DC Reverse (Vr) (Max)1000V (1kV)
Current - Average Rectified (Io)4A
Voltage - Forward (Vf) (Max) @ If1.85V @ 4A
Reverse Recovery Time (trr)100ns
Current - Reverse Leakage @ Vr25µA @ 1000V
SpeedFast Recovery =< 500ns, > 200mA (Io)
Mounting TypeThrough Hole
Package / CaseDO-201AD, Axial
PackagingBulk
Capacitance @ Vr, F-
TNRabbit
Carver SD/A-360 CDP
TNRabbitOffline
#89 Posted: Sunday, April 29, 2012 12:43:16 AM(UTC)
TNRabbit
Medals:
Rank: TO-247 Member
Groups: Member
FYI..
Sent these off to Bob for troubleshooting....
TNRabbit
Carver SD/A-360 CDP
Nahash5150Offline
#90 Posted: Sunday, April 29, 2012 2:11:05 AM(UTC)
Nahash5150
Medals:
Mentor: Tirelessly shares their knowledge with othersSite Builder: major contributor to the Carver site! community.Technician: repair specialist
Cee-Bang!: donated to fund CARVER site! hostingCarver modified: Carver mk II, or self-modified ownerBill D modified: audio equipment owner
DIY: Black Pearl device for multiple award; master builder
Groups: Member
Was thanked: 231 time(s) in 200 post(s)
Gave Thanks: 102 times
Dang. Sorry about all that trouble TNR...
I work on audio systems a lot, and when I hear that kind of buzzing two things come to mind - bad ground OR bad input connection. On rare cases a transformer can do that when they get old and their chassis literally vibrates with the 60hz hum and is amplified (very slightly). IMO the source of the buzzing could have come from the source of the audio signal, especially the jack of the source. A cracked lead or short of any kind in the input source can cause that kind of noise. That, in my mind explains why the only common souce of the buzz was not either of the amps, but the input source itself.
Rss Feed Atom Feed
Users browsing this topic
11 Pages«<7891011>
Forum Jump
CARVER site! theme by Richard G. Pecoraro
Powered by YAF 1.9.5.5 | YAF © 2003-2011, Yet Another Forum.NET
This page was generated in 1.111 seconds.
Follow Us
follow on Pinterest
Join our facebook group
CARVER site! audio forum on facebook
CARVER site! Toolbar install
Follow Us
follow on Pinterest
copyright© 2008 thecarversite.com All rights reserved
