Sunfire Classic Tube Control Center
Kappa man
Hey guys, this message is for the guys whom have owned and figured out the dos and don'ts with the Sunfire tube control center.  I have never had nor know ANYTHING about tube gear ! Over the weekend I made a long drive to pick up a supposedly original owner unit that was recently overhauled by Roland at -Hi-Fi.  The owner said Roland did not like the tubes the owner had put in there.  The control center does have the phono section.  Ive read that these units (although  magnificent), are very finicky to which tubes used. Please help guide me to which ones to use, and where to purchase.  Thanks in advance guys !
Link to comment
Pulled from the owner's manual hope this helps:
https://usermanual.wiki/Sunfire/SunfireClassicVacuumTubePreamplifierUsersManual490041.1949288206/view
Tube type and location
Phono Board
V1 6DJ8 or 6922
MC amp
V2 6DJ8 or 6922
MC amp
V3 6DJ8 or 6922
MC amp
V4 12AX7
MM amp
V5 12AX7
MM amp
V6 6DJ8 or 6922
Infrasonic amp
Line Board
V1 6DJ8 or 6922
Contour amp
V2 6DJ8 or 6922
Line amp/Bal amp
V3 6DJ8 or 6922
Line amp/Bal amp
Note: 6922 Tubes are preferred as they
have less noise and microphonics than 6DJ8s
Link to comment
Tubes substitution is a matter of taste and if you are interested in tube rolling you have more options than just the 12AX7 and 6DJ8/6922. I like using vintage tubes and would like to recommend a few that you may wish to consider.
For the 12AX7 the following have identical pinout and will work, but may give you a little less gain :
For the 12AX7 dual triode you can substitute 5751, 7025 or 12AX7A.
GE, Raytheon and RCA made 5751 tubes years ago and these should still be available on eBay or other sites.
GE also made the 7025 tube which was a high quality tube with low microphonics, perfect for keeping  phono sections very quiet.
British tubes labeled ECC83 or B339 from Amperex, Mullard or Telefunken can also be used as they are the same tube as the 12AX7.
Regarding the 6DJ8, the Amperex company made a substitute called the 7308 with gold pins that was amazing. Any British tube designated E88CC can be substituted as it is the same as 6DJ8/6922.
Good luck tube rolling and when you get the best sound you will know when you have chosen the right tubes!
Edited by straylight
Link to comment
This thread is interesting regarding pre-amp tubes that could be used in place of the 6DJ8/6922's.
https://www.diyaudio.com/community/threads/6n1-6n2-6n11-6dj8-in-pre.380485/
Link to comment
