Gene C 1,742 Posted September 23, 2012 Share Posted September 23, 2012 The Chain: Digital Source Waida 171i Analog Source Carver SD/A-490T Other Sources Sharp BD-AMS20U Blu-ray Signal Processors Pre Amp Sunfire TGP-III Power Amp 2 Carver M-4.0T, Carver M-200, Carver AV-705x Speakers Infinity Kappa 9a, Infinity CC-2, 4 Infinity C255ES Subwoofer Infinity PS-312, 2 Martin Logan Dynamo 1000 Speaker Cables Monster Interconnects Monster Power Cables Headphones/Amp System Rack Power Conditioning Monster/ Amps run straight into 20a dedicated circuit. Tuning and Tweaks Other Components 1 Link to comment Share on other sites More sharing options...
PDR 1,189 Posted September 23, 2012 Share Posted September 23, 2012 Beautiful system, you should be very proud. I would love to hear the Infinity set up one day. Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted September 23, 2012 Author Share Posted September 23, 2012 Beautiful system, you should be very proud. I would love to hear the Infinity set up one day. Thanks! Next time your in AZ hit me up. Your more than welcome to hear it for yourself. Link to comment Share on other sites More sharing options...
Guest RodH Posted September 23, 2012 Share Posted September 23, 2012 Nice collection. Bet you have the elusive "good sound". Cheers - and continue to enjoy! Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted September 23, 2012 Author Share Posted September 23, 2012 Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted September 23, 2012 Author Share Posted September 23, 2012 1 Link to comment Share on other sites More sharing options...
Nahash5150 9,369 Posted September 23, 2012 Share Posted September 23, 2012 ah ha! You're running your amps off a power conditioner. Some have current limiting clamps - do check this out to see if that is part of your current starvation problem. Link to comment Share on other sites More sharing options...
DavidR 29 Posted September 23, 2012 Share Posted September 23, 2012 Very nice indeed Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted September 23, 2012 Author Share Posted September 23, 2012 ah ha! You're running your amps off a power conditioner. Some have current limiting clamps - do check this out to see if that is part of your current starvation problem. Nooooo sir. Those amps go straight into a 20a circuit i dropped for the amps alone. That monster power cleaner is for the TV, DVR, Blu-ray, CD all that other stuff that doesn't ask for a whole lot in the way of power. I'll be honest though when i first bought it that was the idea to run clean power to everything, but that changed long before i started playing around with the sunfire amps. The only way those amps would see a power conditioner is if i had one of those huge $1,700.00 jobbies, which i don't think is worth it. Just so you know they not really starved they do an outstanding job. But when im trying to peel my face off i just have to be careful with them is all. Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted September 23, 2012 Author Share Posted September 23, 2012 Very nice indeed Thank you sir! Link to comment Share on other sites More sharing options...
Nahash5150 9,369 Posted September 23, 2012 Share Posted September 23, 2012 Power Conditioning Monster/ Amps run straight into 20a dedicated circuit. This is what mislead me then. It is indeed a very nice system. Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted September 23, 2012 Author Share Posted September 23, 2012 Power Conditioning Monster/ Amps run straight into 20a dedicated circuit. This is what mislead me then. It is indeed a very nice system. Yah, see what you mean. Thank you. Link to comment Share on other sites More sharing options...
weitrhino 1,386 Posted September 23, 2012 Share Posted September 23, 2012 Looking good, Gene. I suspect you've put a fair amount of thought into it. Enjoy! Link to comment Share on other sites More sharing options...
BluesMan57 1,226 Posted September 24, 2012 Share Posted September 24, 2012 Great looking system sir. Thanks for sharing......... 1 Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted September 24, 2012 Author Share Posted September 24, 2012 Looking good, Gene. I suspect you've put a fair amount of thought into it. Enjoy! Yes and no. The amps i had alot of experience with in high school on a pair of Kappa 8's, so the 9's in a way were familiar territory to an extent. The Sunfire took some getting used to, was a little intimidated with a 9.3 setup, position of speakers and room size. The bi pole speakers were a last minute change, needed more of an indirect sound stage for positioning. The learning curve was quick with the help of an spl meter and experimentation with the calibration on the sunfire, had it dialed in within 2 weeks for the time i had. The subs i think were what took the most time getting tuned for the room, alot of crawling and switching involved there, literally....wife thought i had lost my mind. Link to comment Share on other sites More sharing options...
Blues Pwr 762 Posted September 24, 2012 Share Posted September 24, 2012 Nice set-up, equipment and room. Thanks for taking the time to post your pictures, again very nice, congrats, enjoy.............. Link to comment Share on other sites More sharing options...
zumbini 6,092 Posted September 24, 2012 Share Posted September 24, 2012 Sweet setup Gene. Thanks for sharing it. Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted September 24, 2012 Author Share Posted September 24, 2012 Thanks guys, it's an honor to be amongst knowledgeable audiophiles on this forum. Should of joined here years ago instead of being a spectator, this is the least i could do. Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted October 24, 2012 Author Share Posted October 24, 2012 Changing setup around, glad i kept the glass inserts for the doors. Have 2 Silver Seven t's that are going to be going in the empty spots above the other Silver Seven t's courtesy of Papa Joe. He's getting both M-4.0t's along with the trade. The TFM-42's will be running the Sunfire CRS3's. Post more pictures later as it comes together. Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted October 24, 2012 Author Share Posted October 24, 2012 Link to comment Share on other sites More sharing options...
galaxyoilcan 89 Posted October 24, 2012 Share Posted October 24, 2012 SA-WEET!!! Link to comment Share on other sites More sharing options...
Papajoe 220 Posted October 24, 2012 Share Posted October 24, 2012 Gene- I am glad to see that the Silver 7Ts will have a great home. Show us what they look like in the cabinet when you have them set-up. Link to comment Share on other sites More sharing options...
Gene C 1,742 Posted October 25, 2012 Author Share Posted October 25, 2012 Last piece of the puzzle are the 2 Silver Seven t's and then the living room is done dude.......for now Link to comment Share on other sites More sharing options...
