Hi
would like to take out the passive crossovers all together, there is buzzing in one of my speakers and i think its coming from the panel inside the woofer area.
hear it during low bass runs - especially during diana krall songs.
can someone recommend a place or someone that can make me a blank panel?
I will get the binding post and fuse as per parts express.
Thanks
Happy New Year!
Are you sure it isn't speaker farting coming from a bad surround or bad seal between the woofer & the enclosure?
hi
it could be, but i need to double check...every one sleeping now. but i can get it to stop when i hold the wood panels tight against the lower cabinet holding the woofer. i tightened all the screws...some moved others didnt. i also re set the passive crossovers and taped them down...
turns out the buzzing came from the xo board....had to put sound proofing over it... want to replace with a plate like you did...next step....
Something like this should solve the problem:
DSC02807.jpg?t=1279685857
DSC02808.jpg?t=1279685857
