LVMAN777 352 Posted September 22, 2015 Posted September 22, 2015 This is FREE... Uses your PC sound card to create audio frequencies in the range 100 to 15000 Hz. Input frequency using the Mouse or the Keyboard. Select the audio output device if there are more than one on the PC. Adjustable level control. Turn sound on or off without having to exit the signal generator program. The program is a very small 32Kb, when installed. .. To Uninstall go to Control Panel... The Audio Frequency Generator is accessed from the Start Button / Programs... I TESTED IT/IT WORKS/USING PANDA ANTI-VIRUS...IT'S "CLEAN" http://www.ringbell.co.uk/software/audio.htm 1
morris 390 Posted September 22, 2015 Posted September 22, 2015 There are signal generater apps for android and apple too. I used a free one on my android tablet to adjust damping on my TFM-4.0 1
UncleMeat 1,173 Posted September 23, 2015 Posted September 23, 2015 Careful; a pure tone with enough gain can blow out speakers, especially ribbons. And if your ears can't hear it, it does not mean the speaker isn't generating lots of sound energy.
