Thoughts/concerns/suggestions on adding mid bass drivers?
Why?
Narrowed demand should add efficiency and reduce stress/stretching to the Ribbons.
Stronger Mid bass presence as needed.
Current target for each driver set: (open to suggestion)
25 to 400 hz from the Infinity perfect 10 swap already completed.
200 to roughly 10k hz  (considering 4 drivers/channel Infinity Polydome midbass - do not require enclosure)
2k - 20khz for Ribbon driver
Fabricate/mount a panel attached to rear of Ribbon (wings) on each outer side with 4 drivers each.
Gear:
NAD c162 preamps
Active cross over (to be purchased)
Carver M1.5t  (3)   1 amp each @  bass/mid/high
Thanks in advance!
