Guest Douglas Wright Posted January 17, 2010 Posted January 17, 2010 I came across a pair of "Linn Isobarik" speakers - the Sara model. I need some advice before I make an offer. It seems like they could be a pretty nasty thing to drive without the right amp. They can dip down into some really low impedance. I'm wondering if they could smoke a 6250. Any thoughts ?
musinteg 5 Posted January 18, 2010 Posted January 18, 2010 Could you define " really low impedance"...Loudspeaker impedance varies with frequency. A loudspeaker with an "8 ohm" rating can dip as low as 4 ohms at certain frequencies. Certain speakers drop to 1 ohm ( Martin Logan ). I have never owned a pair of Saras', but looking at a few google images, the tweeter looks like a scanspeak d2008 ( shouldn't give ANY impedance problems here ), the woofers are KEF SP1004 8" units in parallell. ( true isobaric ) wiring. You will get some dips into the 2-3 ohm range, but unless you are driving test tones through them, I wouldn't be too concerned. If you want to see the worlds most USELESS owners manual, go here : http://www.linn.co.uk/owners_manuals and look up the SARA manual. I'm quite familiar with many carver products, but not so with a 6250. Anyone else care to wade in ? Rob
Guest Douglas Wright Posted January 18, 2010 Posted January 18, 2010 Thanks for your reply Rob. It pretty well squares with the little bit of (useless) info I've been able to find. It seems that Saras are nominally 4 Ohms - lower in the treble region - as the amp is driving one tweeter (on one crossover) and a resistor (on the second crossover). They do have a dip at about 4khz to 2.6 ohm. Numbers for the 6250 receiver are 8 ohm/125w - ch, and 4 ohm/140w - ch, and 2 ohm dynamic power/ch is 145w. That being said, real world experience suggests 6250 power transistors are susceptible to over-heating to the point of failure if they are pushed too hard. Therein lies my concern. The Linn Isobaraks are unknown territory for me, and I tend to err on the side of caution. But I really want them if they will do no harm.
BillD 239 Posted January 18, 2010 Posted January 18, 2010 You typically don't need nearly the power at 4kHz that you do at, say, 40Hz. I'd certainly risk the low impedance at that frequency rather than a frequency demanding a lot of power (to move lots of air).
