Gary Beyer 2 Posted March 23, 2022 Share Posted March 23, 2022 The rotary selector switch on my Carver C1 preamp has become increasingly problematic when switching to the Aux1 and Aux2 inputs. Usually I have to wiggle it back and forth a bit to get both L & R channels to work correctly. I have put up with it for years, but of course it has gotten worse to the point I need to do something. It seems as if the contacts are shifting internally and I've had thoughts of disassembling the switch to see what's going on inside, but with no replacement part available, I would be stuck if I ruined it. So... Has anyone else solved this problem? What did you do? I do have DeoxIT D5 contact cleaner, but I'm not sure if there are enough openings to allow it to penetrate sufficiently. I also realize it's likely a temporary fix at best. Gary 2 Link to comment Share on other sites More sharing options...
RobertR 847 Posted March 23, 2022 Share Posted March 23, 2022 Many a C-1 has had that problem, and had it fixed with some Deoxit or other such product. Before trying anything else, spray those contacts, then work the switch a bunch of times. If this fixes it, the cure should last for years. RobertR 2 Link to comment Share on other sites More sharing options...
