Ron L 3 Posted August 18, 2024 Posted August 18, 2024 Hi, I just joined this group. I’m using a Carver HTR-880 receiver that’s lain dormant in my home for a few years. It works great with my newly acquired B&W speakers. Only one problem: either the RH-88 remote no longer works or the IR receiver in the Carver unit doesn’t work. There’s no replacement for an RH-88 but I’m wondering if anyone has had success with a universal remote, or any other ideas. Thanks for listening! 😀 2
Sk1Bum 12,443 Posted August 18, 2024 Posted August 18, 2024 Hi Ron and welcome to thecarversite.com. I found a few with this google search: https://www.google.com/search?q=RH-88+remote&sourceid=chrome&ie=UTF-8#ip=1 Here are three that look promising, but caveat emptor... VCARVER RH88 RH88 Ready-to-Use Redi Remote (Disclaimer: I have never done business with these folks.) https://www.remotes.com/carver-p/carver rtrh88.htm Ebay listing: https://www.ebay.com/itm/325750734469 Picclic listing: https://picclick.com/Carver-RH-88-Genuine-OEM-Audio-Original-Remote-Control-145340799114.html I hope that helps, or at least gets you started in the right direction. 1
Ron L 3 Posted August 18, 2024 Author Posted August 18, 2024 Thanks for the references. I also found those. The $80 choice is way too much and even $35 seems too much. I’m wondering if a $15 universal remote might be a solution. 1
