maytag 892 Posted October 21, 2016 Posted October 21, 2016 Never know when you might need one. The newer Halotron may even spare your electronics. Every hifi systems should have one. http://gizmodo.com/5684978/extinguish-fires-without-extinguishing-your-electronics Halotron I extinguishers, like carbon dioxide units, are "clean agents" that leave no residue after discharge. Halotron I is less damaging to the Earth's ozone layer than Halon 1211 (which was banned by international agreements starting in 1994). This "clean agent" discharges as a liquid, has high visibility during dischage, does not cause thermal or static shock, leaves no residue and is non-conducting. These properties make it ideal for computer rooms, clean rooms, telecommunications equipment, and electronics. These superior properties of Halotron I come at a higher cost relative to carbon dioxide. 3
UncleMeat 1,175 Posted October 21, 2016 Posted October 21, 2016 If you use dry chemical you might as well throw the component away; it's corrosive. But, it would save your home from going up in flames in an emergency. CO2 is also OK for electrical fires.
4krow 7,922 Posted October 22, 2016 Posted October 22, 2016 A buddy of mine in FL has had 2 electrical fires...no make that 3. 2 of them were stereo related! In the last fire, he tried to use a fire extinguisher but for some reason it failed and he got his hands pretty burned up. Makes me want to look into getting one of these Halon extinguishers. did I spell that right? where am I? wtf
maytag 892 Posted October 22, 2016 Author Posted October 22, 2016 A buddy of mine in FL has had 2 electrical fires...no make that 3. 2 of them were stereo related! In the last fire, he tried to use a fire extinguisher but for some reason it failed and he got his hands pretty burned up. Makes me want to look into getting one of these Halon extinguishers. did I spell that right? where am I? wtf Maybe one for your buddy also- as a gift..
