danowood 2,167 Posted February 15, 2017 Posted February 15, 2017 http://encycolorpedia.com/353839 or http://www.lowvolumepowder.com/RAL-7016-4-Oz-Touch-Up-Paint ? 2
zumbini 6,147 Posted February 15, 2017 Posted February 15, 2017 Well, there's a wide range of variation amongst Carver anthracite gear, but I think both of those are way too dark. 838383 is a fairly close match to some of my M-500t's but you can't use paint to touch up an anodized faceplate. 2
loner_t 2,568 Posted February 15, 2017 Posted February 15, 2017 I am trying the Cardinal Pearlescent Bronze on the covers for powder-coating. The RAL-7016 was unavailable at the shop I am using, but I will ask again. 3
zumbini 6,147 Posted February 15, 2017 Posted February 15, 2017 The anthracite on this aluminum anodizing color chart from the 80's might be what Carver used. 2
loner_t 2,568 Posted February 15, 2017 Posted February 15, 2017 The anthracite on this aluminum anodizing color chart from the 80's might be what Carver used. The CI-78 and the C-45 look very familiar. The 1984 M500t that I sent details to you of, seems to have the C-45 or C-0. The power switches vary between CI-78 and C-32.
4krow 6,580 Posted February 18, 2017 Posted February 18, 2017 That's the thing. Mostly it is desirable to match these colors. Then there are times that you can get away with contrasting color or a close enough match that the eye doesn't get bothered by it. The real problem that I have in any case is finding a coating that is durable enough for even normal use.
danowood 2,167 Posted February 18, 2017 Author Posted February 18, 2017 That's the thing. Mostly it is desirable to match these colors. Then there are times that you can get away with contrasting color or a close enough match that the eye doesn't get bothered by it. The real problem that I have in any case is finding a coating that is durable enough for even normal use. Yes only durable finish I can think of would be either a powder coating or an epoxy.
loner_t 2,568 Posted February 18, 2017 Posted February 18, 2017 The color I have tried looks like the CI-75 in Z's chart. This is powder-coated. Putting all three in one photo (Closest - Anthracite, Back - Flat Black, Rear - CI-75/Bronze. Excuse the dust bunnies). 1
