Charlie 20,152 Posted January 12, 2019 Posted January 12, 2019 When I first open up the Sort By option list, it's showing "Last Reply". I can change it but after I back out of everything and then return, it has gone back to "Last Reply" again. Is this some sort of default or can it be changed to whatever I want with the idea that it will remain that way unless I change it again? 1
Nahash5150 11,241 Posted January 12, 2019 Posted January 12, 2019 10 minutes ago, Charlie said: When I first open up the Sort By option list, it's showing "Last Reply". I can change it but after I back out of everything and then return, it has gone back to "Last Reply" again. Is this some sort of default or can it be changed to whatever I want with the idea that it will remain that way unless I change it again? If you go to 'Edit Album', you can change the default sort order. 2
Charlie 20,152 Posted January 12, 2019 Author Posted January 12, 2019 Gawd do I feel dumb; I must have looked at that a dozen times and nothing clicked. Thanks, Greg! 1
