RichP714 3,167 Posted February 27, 2019 Posted February 27, 2019 first Centrifugal force isn't , now tidal forces?
jvandyke_texas 436 Posted February 28, 2019 Posted February 28, 2019 He gets some of it right. I was in Honors physics class in my first year, and one assignment was to mathematically describe the tides. I got the right answers at selected points, but not the overall function. Function was 3rd order and had an R^3 in it. The way to find the solution is as he says, to treat earth as totally covered in water. Then you assume if there is a change in gravitational potential, water will flow. So the whole earth has an equipotential surface. Calculate that, and you have the tides. I think it was about a meter. The reason why Bay of Fundy in Nova Scotia has such high tides is because there's a body of water that has a resonant frequency equal to the tidal period. Water sloshes in and out with a period of 12 hours. 1
RichP714 3,167 Posted February 28, 2019 Author Posted February 28, 2019 13 hours ago, jvandyke_texas said: .....The reason why Bay of Fundy in Nova Scotia has such high tides is because there's a body of water that has a resonant frequency equal to the tidal period. Water sloshes in and out with a period of 12 hours. Yes, I'm not sure why he didn't explore that; perhaps he didn't want to obfuscate the main topic
