C-los 3 Posted January 20, 2021 Posted January 20, 2021 just wondering where to find all the capacitors for these awesome amps and what if u can’t find the exact one. Thanks 2
Sk1Bum 13,259 Posted January 20, 2021 Posted January 20, 2021 Hello C-los, and welcome to thecarversite.com. We're glad you're hear. There is a lot of information here, much technical know how, and a pretty good bunch of folks that are happy to help. Mouser and digikey are often mentioned by the resident techs as good sources. Hopefully one of them will chime in here with suggestions. Once you get to Novice status, please consider uploading some pics of your gear in the Members Systems area. We all like pics of all kinds of audio gear. In the meantime, kick your shoes off, turn up the music, and welcome aboard. 2
Community Admin AndrewJohn 11,102 Posted January 21, 2021 Community Admin Posted January 21, 2021 Welcome to the site. The main menu above on the main login screen will help you find the manuals. Many of us use Mouser.com or Digikey.com for sources of components. Mouser out of TX, seems to be the highest level of CS..., for me. DigiKey is also very reliable. Sometimes one vendor will have items the other does not - or better prices..., it is time-consuming research, and both sites have "specifier" wizards..., for dimensions, type, voltage, etc., to narrow down the possibilities in their inventor. Welcome to the site! Post a thread on your restoration..., with pictures, of course! many here will chime in with helpful guidance. 1
