gwolford 5 Posted September 29 Posted September 29 I am trying to find what belt circumference will work for SD/A360 cd player. I saw the number .065 inches which is 1.7mm, would 1.5 mm work? 2
BobTFM35 3,423 Posted September 29 Posted September 29 (edited) Welcome to the Carver Site!! Tell us more about yourself and your equipment. Download the file in this link to find belt size information. And for good measure look at this Edited September 29 by BobTFM35 added link 2
Sk1Bum 13,836 Posted September 29 Posted September 29 Hello gwolford and welcome to thecarversite.com. Glad you found us. BobTFM35 steered you in the right direction. Good luck with your search.
gwolford 5 Posted September 30 Author Posted September 30 Thank you for the help and welcome messages. The thread about the cd player was very informative. I ordered a package of 2 mm belts of various sizes. I have a A500x amplifier, a CT24 pre-amp tuner and the SD/A-360 player. I am in California. 3
MattB 368 Posted October 2 Posted October 2 Tagging onto this thread for somewhat relevant question... Is there a good place to order belts by size? I have a VPI turntable and the belts are $45 each direct from VPI. I can't imagine these are anything super duper esoteric, but they sure do like to charge for them.
BobTFM35 3,423 Posted October 2 Posted October 2 (edited) @MattB @gwolford A few places I have in my saved folder, Listed in no particular order https://lptunes.com/collections/vpi-turntable-belts https://www.lpgear.com/category/V1.html https://www.turntableneedles.com/Rubber_Drive_Belts-Tape_Decks_Turntables Was able to source a tt belt from Amazon based on knowing the size and cross section information. For mine I used this to start the search; Turntable Belt for Record Player 20.7" Replacement Flat Medium Edited October 2 by BobTFM35 2
MattB 368 Posted October 2 Posted October 2 Many thanks, Bob! This one has a round belt- looks just like a vary long O-ring with about 2.5mm thickness. I searched amazon for quite a while and only found flat bands in that size. I'll keep digging on the sites you linked. 1
BobTFM35 3,423 Posted October 2 Posted October 2 https://www.turntableneedles.com/round_rubber_drive_belt_medium 2
MattB 368 Posted October 2 Posted October 2 yeah I saw those. I think I looked a while back and their largest was just a touch short. I'll have to re-measure the existing one when I get back from the track this weekend. many appreciates! 1
