recommendations for replacement tweeter for realistic Optimus T-120 Speakers
Guest ubgfleming
Morning all,
Ok, I was able to come across a pair of T-120 speakers from the garbage. The cabinets were in fine shape but the speakers were blown.
So, I replaced the woofers and mid-ranges. But the tweeters I am having problems with.
Here is a link to what the speakers look like:
http://www.canuckaudiomart.com/details/98306-realistic_optimus_t120_speakers/
ANY help is really appericated and if i posted this in the wrong spot, please direct me for proper posting in the future!
Thanks all!
Greg
Hi UBG,
My personal experience has been that if the replacement driver is not 100% capatable with the speakers x-over design, the other drivers' L/R/C parameters (i.e., coil windings match, wire dia match for R, etc.) then the sound from the speaks will be "lacking" and not close to 100% of what they could/should sound like. Even suspecting these kinds of deficiencies can drive you crazy.......and sound WILL be less then optimal in most cases (especially multi-driver systems where "other" un-matched driver issues can manifest). Best to bite the bullet and use ONLY 100% original replacement drivers meant for that speaker. If no longer available (new), then resort to ePrey and "cannibalize" a used set of the same model for the replacement drivers you need.
