RichP714 3,181 Posted August 27, 2009 Posted August 27, 2009 http://sound.westhost.com/compression.htm
Harryfan 36 Posted August 27, 2009 Posted August 27, 2009 Sounds like the same issue that Perry brought up a while back. http://thecarversite.com/yetanotherforum/default.aspx?g=posts&t=645
RichP714 3,181 Posted August 27, 2009 Author Posted August 27, 2009 I knew it was covered, but couldn't find the thread.....
Guest CraigCyril Posted January 27, 2012 Posted January 27, 2012 Dynamic range compression, also called DRC (often seen in DVD and car CD player settings) or simply compression reduces the volume of loud sounds or amplifies quiet sounds by narrowing or "compressing" an audio signal's dynamic range. Compression is commonly used in sound recording and reproduction and broadcasting.
