I've got a couple of these JBL corner subs, never hooked 'em up. Seem quite efficient. I should put two CRM-2's on top... Hmmmeusa_think.gif
Stereo Input Dual Coil Subwoofer
The Control SB-2 provides low frequency reinforcement in subwoofer/satellite systems. The Control SB-2 is ideal for foreground music and music/paging systems in restaurants, retail establishments, theme bars, music cafes, health clubs, and other indoor applications.
FEATURES
  • Components: 250 mm (10 in) dual voice coil transducer.
  • Stereo inputs with high-pass outputs for satellite speakers.
  • Slot-load vented bandpass design.
  • Complemented full range Control Contractor Series systems.
  • High Sensitivity: 100 dB, 1 W, 1 m.
SPECIFICATIONS
Frequency Range 38 Hz - 160 Hz (-10 dB)
Power Capacity 340 W (both inputs driven)
Sensitivity 100 dB (1W, 1m) at corner
Nominal Impedance 8 ohms per input; 4 ohms total
Network Filter to Subwoofer 12 dB / oct low-pass (per input), 160 Hz.
Acoustic Filtering 6 dB/ oct lo-pass filtering via slot load design, 80 Hz
Network Filter Satellite Outputs 6 dB/ oct high-pass (per output).
Drivers 250 mm (10 inn) long throw with dual voice coils.
Enclosure Material Particle Board
Terminations Spring terminals, accepts banana plugs. Left In, Right In, Left Satellite Out, and Right Satellite Out.
Installation Accessories MTC_SB2W for installing SB-2 onto a wall or into a corner. MTC-SB2C for suspending SB-2 from a ceiling.
Dimensions (H x W x D) 394 x 585 x 343mm
(15.5 x 23.0 x 13.5 in.)
Net Weight (ea) 19.1 kg (42 lb)
Shipping Weight (ea) 22.7 kg (50 lb)
  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
What's with the specs on those Kevin? 38 Hz to 140 Hz -10 DB??
JBL can be conservative on it's spec's sometimes. I guess I gotta plug 'em in. Well, hook some amps up to them. Perfect duty for two of those DA-2's. No room for these subs right now.
Everyone should at least HEAR a JL Audio Gotham at some point in their life. The MACK DADDY of subwoofers, with a price to match: $12,000.00 MSRP.  Two massive 13.5" subs with a 3,800 watt (RMS) amp & room correction software.  The utter smoothness & UNGODLY KICK literally take your breathe.  I guarantee you've never heard anything remotely like it.
http://www.jlaudio.com/home-audio-powered-subwoofers-gotham
Hey Rabbit, just read the specs on them, 4" of excursion! That's totally nuts.
 So I'll keep an eye out for them in the thrift stores.
BillWojo
