cuda 595 Posted July 31, 2015 Posted July 31, 2015 Bought a sunfire TGP-5 and when testing it (volume up) it distorted and blew the bass fuse on my ALIII. Replaced fuse but no ribbon working. (These have the high/low strips in place) So both fuses are good, checked the ribbon and it is fine. So something in the crossover is bad. I can open up my other amazing and then compare values with my multimeter to try and track down the bad component or is there a better way to find what is blown?
kve777 6,911 Posted July 31, 2015 Posted July 31, 2015 Sounds like the right way to diag them, break out the DMM. I have a pair of AL-III+(no pots) crossovers and a 48" ribbon if you need parts.
TNRabbit 371 Posted July 31, 2015 Posted July 31, 2015 If you open it up, it may be clear upon visual inspection what component is bad...
cuda 595 Posted July 31, 2015 Author Posted July 31, 2015 Ends up not the crossover, the famous daughter board connection to the mylar is bad the circuit trace is worn through, I have a trace pen and the gunk is drying right now but I need to send it in to be happy with this. I had read that there was a current delay in the materiel order right now so a quick ribbon rebuild sounds out for now.
PMAT 2,144 Posted July 31, 2015 Posted July 31, 2015 I would love to see a documented ribbon rebuild. The Kapton issue seems to be a long running problem.
kve777 6,911 Posted August 1, 2015 Posted August 1, 2015 I have the tweeters from SteveMKentucky's CRM-2's apart. I am going to attempt to build new diaphragms. I have Kapton tape(actually called Koptan, it's a knock-off)and am awaiting the arrival of some copper tape. The originals are aluminum foil, but I want to try copper as well. I will cut by hand at first. Also, I will try a plotter cutter for vinyl. If I can get it right, it would be quick and easy. I have a working AL-III ribbon, but don't want to ruin it. If anyone wants to ship me a bad Amazing ribbon, I will attempt it. 2
