Jamel 0 Posted November 10, 2015 Posted November 10, 2015 Hello, I was given this receiver years ago. It came along with an amp. I noticed years ago that I was able to connect speaker directly to the receiver as well, but when I attempted to do so I get no sound. I did notice that when I turned on the receiver the screen flashes Pre - On. This seems like its only acting as a pre-amp and not both a pre-amp and receiver. Is there anyway I can utilize this receiver as both a pre-amp and a receiver so that I can connect speakers directly to it? Any help anyone gives me on this will be greatly appreciated.
Balok 1,863 Posted November 10, 2015 Posted November 10, 2015 Check the back of the unit. There will be jacks that say "pre out" and "main in" or something similar to that. those need to be connected with pins or short rca interconnect cables. See area circled red in picture below. My guess is that is your problem. 2
Balok 1,863 Posted November 10, 2015 Posted November 10, 2015 On second thought, if the unit flashes "pre on" then my suggestion above is probably not the answer.
kve777 6,911 Posted November 10, 2015 Posted November 10, 2015 That PRE ON message means it's in protection. Knowing the age, it's probably due for a major service.
zumbini 6,154 Posted November 10, 2015 Posted November 10, 2015 Howdy Jamel and welcome to the forum. Before you dump it, or have it serviced, please confirm that the pre-out/main-in jumpers are in place as Balok suggested. If you don't have the original u-shaped metal jumpers, a short pair of RCA cables will work equally well. If you need to drive an amp too, replace the jumpers with dual male to single female Y-adapter cables.
Herbies101 14 Posted November 10, 2015 Posted November 10, 2015 He!! yea Balok !!! Thank you so much for that tip. I bought a HR-752 to use for my tv entertainment setup for 25 bucks off craigslist as not working...turns out your little tip right there get her working!!! Im so pumped and thankful dude!!! Thanx again Bob
Balok 1,863 Posted November 11, 2015 Posted November 11, 2015 I just happened to be manning the INADVERTENT HELP HOTLINE yesterday. 1
