PMAT 2,155 Posted May 15, 2016 Posted May 15, 2016 hi guys I can't figure this out so I thought I would go to the collective. I have four pairs of infinity speakers. I'm trying to repair it and find good homes for some. My current project is the RS6 three way speaker. They were rotting in someone's garage so I've repaired all that. But the two speakers came with two different woofers, they are both Polycone 8 inch infinity drivers. One of them however is four ohm and the other is eight. The magnet size is different too. Everything I find it says it's either four or 8 ohms. Nothing specific to this particular model. How can I figure out what is needed? Anyway to know that from the crossover?
zumbini 6,154 Posted May 15, 2016 Posted May 15, 2016 Perhaps the RS6 and RS6B used different woofers and one was used as a replacement for the other? 2
danowood 2,167 Posted May 15, 2016 Posted May 15, 2016 Dom, thats exactly what I was thinking too. One had been replaced with the wrong driver. The xover should tell the story I would think. If they are matching x overs in the box then one driver has been replaced with wrong driver. Perhaps the x overs can direct which model it's suppose to be.
RodH 4,868 Posted May 15, 2016 Posted May 15, 2016 I was looking for info on the difference between the RS-6 and RS-6B, but there doesn't seem to be much out there. Anyone know?
zumbini 6,154 Posted May 15, 2016 Posted May 15, 2016 Infinity's historical reference page lists the 6 and 6b together on one page with the same specs. The only differences I see are the model numbers, pinstriping, and the address blocks on the binding post plates.
RodH 4,868 Posted May 15, 2016 Posted May 15, 2016 I saw that. There must be some reason for the 2 different woofer impedances though. 1
PMAT 2,155 Posted May 15, 2016 Author Posted May 15, 2016 Crossovers are identical. I had a pair of the RS6B as well. I pulled the Drivers and chucked the damaged cabinets, That pair had both woofers replaced with the wrong drivers. These speakers are typical 30 year old units in need Of love. I just can't throw them away. They sound really good Compared to most cheap speakers nowadays. I would like to just buy a couple of refoamed woofers. Then I can give these to someone who would appreciate them.
zumbini 6,154 Posted May 15, 2016 Posted May 15, 2016 Here's contact info for Infinity/Harmon North America: Customer Service US (800) 553-3332 Canada (514) 457-6674 Mon -Fri: 9:00 a.m. - 11:00 p.m. (ET) Sat - Sun: 9:00 a.m. - 5:00 p.m. (ET)
PMAT 2,155 Posted May 15, 2016 Author Posted May 15, 2016 Wow. Didn't think of that! I'll give it a shot.
zumbini 6,154 Posted May 16, 2016 Posted May 16, 2016 When in doubt, go back to the source... Have the serial #s handy when you call them. If the paper labels have fallen off (typical) check the crossover boards.
