TomcatCrew 11 Posted April 17, 2018 Author Posted April 17, 2018 Chops - Two quick questions - Whats the difference between the 4000 and the 4000t I'm looking at Tuners - I don't listen to a ton of AM/FM. That being said, do I really need the 11a or could I just go with a TX 2 or a TX 8 Thanks! Tom
loner_t 2,571 Posted April 17, 2018 Posted April 17, 2018 (edited) 2 hours ago, TomcatCrew said: I'm looking at Tuners - I don't listen to a ton of AM/FM. That being said, do I really need the 11a or could I just go with a TX 2 or a TX 8 TX8 and TX8r (Remote version of TX8) are black-face, while TX2 and TX11(a) are Anthracite. TX2 closely matches a C2, while a TX-11(a) matches a C-1 more closely. Consider a TX-11, if you do not need AM. Edited April 17, 2018 by loner_t
peck555 366 Posted April 17, 2018 Posted April 17, 2018 (edited) I'm rather partial to the TX-10, it's a good tuner when paired with a good antenna, it's black faced. It also has AM if you need it. Edited April 17, 2018 by peck555 Additional info
zumbini 6,154 Posted April 17, 2018 Posted April 17, 2018 8 hours ago, TomcatCrew said: Whats the difference between the 4000 and the 4000t The C-4000 was produced from 79-85. It had built-in (15 wpc?) amps for the time delay channels and was known to be a bit noisy. The 4000t was produced from 86-89. The time delay channels became line level outputs and some of the noise issues were addressed. 8 hours ago, TomcatCrew said: I'm looking at Tuners - I don't listen to a ton of AM/FM. That being said, do I really need the 11a or could I just go with a TX 2 or a TX 8 Any Carver tuner will produce acceptable results if you feed them via a good external antenna. If you are in an urban location with multi-path issues I recommend the TX-11a or TX-11b. 2
