jeffs 3,457 Posted January 8 Posted January 8 (edited) Years ago I bought a pair of Polk SDA2 for my brother. Didn't know anything about them. Loaded them on their sides into my SUV. Drove an hour home. Tried them out. A few days later - loaded them back up and drove 1.5 hours to his house. Nice speakers. Today I'm going to pick up a pair of Monitor 10. I was bored yesterday and started reading up on them. Came across a magnet shift issue that may occur under various conditions .... a solid hit, or transporting them on their sides. Now I'm kind of paranoid about getting them home (1.25 hours). I know there are a few Polk experts out there. I will be able to transport them on their backs, which seems to be preferred. Would this be sufficient, or should I remove the drivers for transport? I do plan on glueing the magnets once I get them home. Thanks. Edited January 8 by jeffs 3
4krow 7,239 Posted January 8 Posted January 8 I remember many years ago when moving a set of large JBL 4343 speakers, that I first put down a mattress, and then laid the speakers on their backs. Gluing the magnets won't do much good if you can't center the magnets first. I would think that a solid adhesive like JB Weld is the way to go when you get to it. 3
BobTFM35 3,039 Posted January 8 Posted January 8 (edited) Good to know about the magnet shift issue for these speakers. This looks like a fun project. Per Jeff's comments below, methods on the Polk forums look to be more correct, so I removed the video so as Not to be misleading. Edited January 8 by BobTFM35 1
jeffs 3,457 Posted January 8 Author Posted January 8 45 minutes ago, 4krow said: Gluing the magnets won't do much good if you can't center the magnets first. I would think that a solid adhesive like JB Weld is the way to go when you get to it. Correct - if they are still OK when I pick them up, my goal is to NOT disrupt them until I get a chance to glue them. JB Weld seems to be one option .... 1
jeffs 3,457 Posted January 8 Author Posted January 8 (edited) deleted content here to make the topic flow correctly Edited January 9 by jeffs my comments here were no longer relevant to the flow 2
Sk1Bum 12,714 Posted January 8 Posted January 8 I moved a pair of these for about 3 hours from St Louis to Springfield with no issues. One was standing in the passenger side floorboard, and the other was standing in the passenger seat. 2
jeffs 3,457 Posted January 8 Author Posted January 8 Bottom line .... I pushed the PRs and made sure the mids did their dance, threw them in the trunk and drove home. No issues. Will revisit the glue if/when I take them apart for wood veneering. FWIW these are Monitor 11A, which is more-or-less the same as the Monitor 10. Bigger box, different mid, maybe slightly different xover? These lived their last 10 years on the ocean .... I mean you could walk across the street straight into the Mystic CT Harbor. The MDF has absorbed a lot of moisture due to constant humidity. The drivers are in excellent shape. If I decide to keep these, I'm going to get a set of the RD-0194-1 replacements as I did for my brothers SDA2. I hope these can still be had directly from Polk? The existing SL2000 tweeters can be harsh and tiring. Maybe rebuild the crossovers with some quality caps as well. For grins I put one on a stand that I've had forever but never used. I think these stands hold 120 lbs. Dying to use them for something, but this won't be it. Anyway - well worth the $100. 2 2
