Vinyl record cleaner
Guest Middlebush
Does anyone of a good way to clean vinyl records? I see hundreds of cleaners on Amazon and E bay. On You Tube they were using wood glue,letting it dry, then peeling it off. A little much I thought. Something that works well without spending hundreds of dollars is what I'm looking for.   Thanks
All dependent on how much you are willing to spend. You can get manual ones from $50-$175. Then you get into the automatic ones, new from 500-2500 and more. Used from 300 and up.
I just picked up one of these.  My family increased my collection by several hundred and I wanted to clean all of them.  Its not quick but it really does a nice job.  The microfibers they supply are a bit weak but I picked up some additional ones from the local hardware store.  I had some really dirty LP's and this really did the trick!
I have a Spin Clean machine also and it does work nicely. I have cleaned about 60 records so far. All manual but at that price it is a good deal.
I'm in the middle of making a DIY spin clean.....when I get
home at the end of the week I'll take some pics....
LOL.....me too!
