Hotrod57 0 Posted November 6, 2015 Posted November 6, 2015 Need help. I have a Sunfire Ultimate Receiver II and have a chance to purchase Martin Logan CLS IIz's. Any idea if the Sunfire will handle the CLS? I realize that the Sunfire is a pretty robust unit but can it handle the 2 ohm load at 20K?
danowood 2,167 Posted November 6, 2015 Posted November 6, 2015 Welcome to the site Hotrod. I don't have a sunfire, as it's out of my budget but there are some here that do and can answer your questions. Sit back, page through the site and someone will be along shortly to answer your question
PMAT 2,099 Posted November 6, 2015 Posted November 6, 2015 In two channel mode it will have trouble unless played low. You would need a sunfire 300X2 or 600X2 or any 400 watt per channel sunfire multiple channel amp running in two channel.
Balok 1,828 Posted November 6, 2015 Posted November 6, 2015 I have used my ultimate receiver ll to drive my Carver ALS originals. I have read that they can dip below 1 ohm (confirmation needed). The combination sounds great but I listen at relatively low-moderate levels. If you really want to crank it loud I would probably recommend a stand alone Sunfire amp as suggested or you could get a Carver M1.0t with upgrade modifications done by one of the forum techs.
weitrhino 1,445 Posted November 6, 2015 Posted November 6, 2015 It would be helpful if you put up some specs on the MLs. I have a UR-I and it handled my Amazings pretty well back when I was doing that. The UR is basically a TGP-III and a Cinema Grand rolled into a single chassis.
LVMAN777 390 Posted December 9, 2015 Posted December 9, 2015 Don't have a Sunfire Ultimate Receiver.....BUT Can you program it to output a stereo signal through two channels on each side and by-amp each speaker... With 200-400 watts for the woofer And 200-400 watts for the ribbon on my ALS III's...???
Offcourse_dk26 0 Posted May 2, 2016 Posted May 2, 2016 Im looking into this as Well, using the 8 CH input to Biamp speakers is my plan, using more modern HDMI receiver as controller and the Sunfire urII as power AMP. Would this Work? Sure hope so
