Adam hockenbroch 5 Posted January 7, 2025 Posted January 7, 2025 hello all I have two different amps looking for manuals for both? Carver TFM-35 and Sunfire cinema grand 5 channel, the back looks like a series 2 but has a cord that is not removable,can anyone help? 5
3M_Audio 2,286 Posted January 7, 2025 Posted January 7, 2025 Hello Adam and welcome. Click on the 'Manuals and Specsheets' link at the top of any page and you find all the manuals collected by TCS. 2
Sk1Bum 12,864 Posted January 7, 2025 Posted January 7, 2025 Hello Adam, and welcome aboard. Glad you found us. Nice amps, both are popular here! Once you get to Novice status, please consider uploading some pics of your gear. We all like pics of all kinds of audio and home theater gear. 1
Community Admin AndrewJohn 10,836 Posted January 7, 2025 Community Admin Posted January 7, 2025 Welcome, @Adam hockenbroch, so glad you found us. You will find the manuals that we have in our library in the Manuals Library, top menu of home screen. When the index loads (sometimes it hesitates) it will display what looks like a spreadsheet. click on the tab at the bottom for Carver (default) and for Sunfire) next to it, to get to the sunfire library of what we have. Again, welcome, and glad you found us! Post a pic or two of your gear when you get a chance..., we love participation, and posting a pic of your setup is a good way to brag a bit 😉 1
jeffs 3,485 Posted January 7, 2025 Posted January 7, 2025 welcome. You won't find a manual specific to the older versions of the Sunfire Cinema amps. Mostly the newer owners manual will suffice ....... inputs and outputs are probably going to be in different spots, but clearly marked. Other than I/O the only other feature on the back is the on/auto/off switch which I believe works the same for all of the amps, so any description from another manual will do. The older amps do not have an external trigger input. If you need a schematic, you're likely going to be out-of-luck. I have 2 Cinema amps and the schematics here are not very close. 3
