Retriever 1,128 Posted July 22, 2013 Posted July 22, 2013 Ok I finally ran out of the Ol permastat Lp cleaner what's good these days?
snow 240 Posted July 22, 2013 Posted July 22, 2013 Ok I finally ran out of the Ol permastat Lp cleaner what's good these days? Not sure if this stuff works or not but if you want to give it a try I will send it to you as a Karma.
Retriever 1,128 Posted July 22, 2013 Author Posted July 22, 2013 My signet cleaner looks just like that, I'm just running out of the cleaning fluid and wondering what's good these days? Not all my LP's were treated with permastat, and I want to find a good fluid to clean.
Retriever 1,128 Posted July 22, 2013 Author Posted July 22, 2013 heres what my cleaning brush looks like. Thanks for the offer Snow, but I just need a good fluid!
Maddmaster 1,011 Posted July 22, 2013 Posted July 22, 2013 Ok I finally ran out of the Ol permastat Lp cleaner what's good these days? It's still available on amazon. http://www.amazon.com/s/ref=nb_sb_ss_sc_1_11?url=search-alias%3Daps&field-keywords=discwasher+fluid&sprefix=disc+washer%2Caps%2C209 1
snow 240 Posted July 22, 2013 Posted July 22, 2013 heres what my cleaning brush looks like. Thanks for the offer Snow, but I just need a good fluid! OK it's being sent to Danowood as a Karma then, this contains a bottle of cleaning fluid as part of the kit. REGARDS SNOW 1
danowood 2,167 Posted July 22, 2013 Posted July 22, 2013 Thanks Dan, it will be put to good use. Daughter is getting very excited about the system I'm putting together for her and this will be a very nice piece to clean her records with. Thanks again
snow 240 Posted July 22, 2013 Posted July 22, 2013 Thanks Dan, it will be put to good use. Daughter is getting very excited about the system I'm putting together for her and this will be a very nice piece to clean her records with. Thanks again Your welcome glad I finally had something to Karma away that someone here needed. REGARDS SNOW
kve777 6,889 Posted July 22, 2013 Posted July 22, 2013 Ok I finally ran out of the Ol permastat Lp cleaner what's good these days? My formula is 2 cups water to 1/2 cup isopropyl alcohol with a few drops of Dawn dish detergent. Best if water is distilled. Alcohol at 92%. You can put it in a dropper type container or a spray bottle. 1
kve777 6,889 Posted July 22, 2013 Posted July 22, 2013 Strange But True! I just remembered this- An old friend of mine has an extensive collection of 45's for his jukebox. He uses WD-40 on them! Seriously! He sprays the crap out of them before loading. I can hear the degradation of sound quality, but he thinks it sounds great. I don't think I'd ever try that with a record, cartridge or TT that I cared about. The only positive I can imagine is reduced friction for longer stylus life. High frequency response goes right out the window as the fluid dampens movement. Platter slippage must be crazy, too.
RichP714 3,163 Posted July 23, 2013 Posted July 23, 2013 can a moderator please relocate this to the vinyl category? btw, alcohol is not needed to thoroughly clean vinyl; it destabilizes the surface, eventual erosion and high frequency loss
