Nahash5150 11,231 Posted February 1 Posted February 1 I may or may not do this...I'm having second thoughts. 'The guts just come out and go right into the new chassis...' Ha!!!!! It wouldn't be too bad if the transformers could just 'unplug' but they don't. Their wires travel everywhere...and that's real problem. There's no room for error - the wire lengths are precise. 3 transformers - each with 8 to 20 wires. All rivets have to be drilled out. All RCA jacks need to be replaced. The thing needs a severe cleaning and polishing. And the worst part - HUMAN HANDS. Previously worked on and it doesn't work. Worst problem ever. I'll need encouragement because I really want to say NO. 1 1 2
Charlie 20,110 Posted February 1 Posted February 1 If it were my decision I wouldn't touch it; too many booger solders and shade tree work going on... 2
Brian K. Totten 525 Posted February 2 Posted February 2 NEW! No Brainer! The new one looks so sweet! 1
Nahash5150 11,231 Posted February 2 Author Posted February 2 Correction - FxBill worked on it and he says it works...so...that is a bonus!
BobTFM35 3,377 Posted February 2 Posted February 2 Greg @Nahash5150 I don't know the back story on why this amp is on your bench. Lets say, its not a customer, but something that you sourced for your own use. If it was for a customer, I might have written the following differently. I did a little research on this amp and I've come to this conclusion. I just hope that I can explain it clearly. First the going price for this model, depending on the condition is maybe 3500 to 5000 (correct me if I'm wrong). That was the asking prices on ebay that I viewed. For discussion purposes lets say I can flip it for $4000.00 and I spend no more than 1200 for parts, don't know the bench time required so I can't factor that in, but it could still come out to be a nice profit. One of my first decisions is on availability of spare parts. You have a very nice Chrome chassis to work with. The vendor that I found for that chassis (and possibly the same one that the chassis was sourced from) also has some very nice reproduction pieces, such as the decals for the transformer covers and either a silver or gold badge 240 badge. For you sourcing the tube sockets, correct wire color and size would be no problem. The other sockets or holders for the metal caps (or whatever they are) I feel that you have the abilities to source them. The pots, depending on their condition, might take some reconditioning. Might need to see if replacements are available. I do know that for the dynaco amps there are a few vendors offering parts for restoration so maybe this is the case for the 240 amp. No doubt you have the wiring diagram for this unit so that would be a great source of encouragement to start with. I might start placing as much on the new chassis as possible such as the tube sockets, pots, and speaker terminal strips, some preliminary wiring with lengths long enough to be later adjusted, thus using the original chassis and schematic as a guide. I do know that you not only have the correct equipment but also the knowledge and experience to tackle this endeavor with a systematic approach, and that in Itself gives it a way better chance for success. Enough encouragement? You have this. 2
3M_Audio 2,545 Posted February 2 Posted February 2 I agree with @BobTFM35 regarding all the parts. The question in my mind would be the labor. There would be a *lot* of it. Your quote (from the customer, I assume) used the word "just". That would set off some alarms in my mind as it would indicate they are thinking it's a simple job that might take a couple of hours. I don't work very fast, but if I was estimating labor for the project I think I'd be at least 20 hours. Would the customer be OK with that bill? I bet they'd be shocked when they heard the number. Still, it looks like it would be a fun project. I have a soft spot in my heart for that vintage point-to-point wiring. It brings back memories of old Dynaco kits. 2
Nahash5150 11,231 Posted February 2 Author Posted February 2 Yeah - 20 hours is at the low end of time. I will not make any money on this. I have bills like anyone else - it's not about making money, it's about being responsible with it. I have to be very careful what work I take. If a project gets too demanding of my attention, other clients suffer. And I certainly do not want a shop full of unfinished projects that are over a year or two old. I told myself I would not do that... Anyway, fxbill is a great salesman. Looks like I'm doing it. For team Carversite...here we go... 2
Nahash5150 11,231 Posted April 4 Author Posted April 4 Transformer out! Parts of this thing haven't been seen by human eyes for over 50 years! Looking simpler with the transformer wires out. Its out!!!! Transformers through the new chassis. This was HARD. Each transformer is so heavy, and the wires are stiff and don't want to move, so getting each one set over the holes - both the wire entry and screw mount holes, is a real challenge. Riveted and screwed in - still a lot of soldering to do. Almost done. New power cord, new fuse holder, and I had to wait for the new RCA jacks because the stock were pressed into the chassis and they ain't comin out. New Speaker Blocks as well: Tubes in, and initial testing. It only has 16dB gain and a max power of 40W per channel, so I was quite shocked at how much metal it takes to make that happen - lol Test result after some tweaking. Spec is 0.5%, and it stays below 0.2% from 1W to 45W so we're good. I can make the THD change based on were I put the 6L6 output tubes, so matching is a factor on this topology. Some cutesy pics: I can look back on it now and call it fun... But it wasn't. HAHAHAHA! 2 1
Nahash5150 11,231 Posted April 4 Author Posted April 4 And a side-by-side: It's really hard to take pictures of this thing because it's like a mirror and I keep spotting myself in the shot! 1 1
BobTFM35 3,377 Posted April 4 Posted April 4 @Nahash5150 Well you did it!! A night and day difference. I really like how the old and the new blends together preserving, shall I say its history and still maintaining some of its vintage look. Looks like you had a very good starting system with all the numbering and tagging that I see. Just those wires poking out of the holes gave me anxiety just looking at them. I'm assuming that they are the original tubes? Interesting to see that the unit used 6L6. Just the other day Chris and I were testing the same 6L6, 5881 and a few other tubes out of his vintage guitar amp with a Sencore TC28. Like I said " You have this" and it came out perfect. Great looks and it beat the numbers. Excellent!! Excellent!! Excellent!! 1
Nahash5150 11,231 Posted April 4 Author Posted April 4 1 hour ago, BobTFM35 said: I'm assuming that they are the original tubes? Interesting to see that the unit used 6L6. Yes - I think they are. As for the pre-tubes - no idea. But I had to provide the AU's cuz Bill didn't send me any! 1
fxbill 474 Posted May 1 Posted May 1 Fantastic work Greg... I just received the amp back today and am truly impressed. You had a chance to use "fake" rivets with no heads, but nuts to hold them and yet you choose to use the real rivets and buck them yourself. Bravo! A little history of this amp for those of you reading this for the first time. I purchased this from the estate of a Mac collector. It was one that nobody else seemed interested in and yet, despite it's looks it was one of Mac's best amps made and this one had all original Telefunken small tubes with the exception of one of the small tubes and the 6L6's which I sourced from an eBay seller who had original Mac tubes for sale. I actually use KT66's in it although I sent it to Greg with the 6L6's since that's what the original used. The power supply was rebuilt with Authenticaps and a couple of NOS Mallories that I had laying around. The unit always sounded great after the PS refurb and I paid $1000 for the unit and about $350 for the chassis and hardware. Combined with Greg's more than generous labor cost...Thank you again Greg... I am into this unit for far less than one not even close to matching the looks of this one. I was shocked at the specs that Greg got out of the unit. Now it looks as good as it sounds! Thank you again for such detail and quality that only you can provide Greg!! Kind Regards, Fxbill 3
