B-Man 4,781 Posted April 23, 2015 Posted April 23, 2015 Just thought I'd share something I tried on a whim. I have been ripping my entire CD collection again into FLAC files and noticed that the PC was having a hard time with Jackson Brown - Running On Empty. I ejected it and discovered that it had a pretty long scratch running diagonally from the center hole almost to the outer edge. I figured that there was nothing to lose, so I grabbed a microfiber cloth and some of this from the garage : I use it to take hazing and small scratches out of vehicle paint so how bad can it be, right ?? Not to go too hard against the common consensus (which is to not rub a CD in a circular motion) I put a little of the glaze on the rag and rubbed it in a circular motion until I could no longer see the scratch. Actually, it was still faintly visible from an angle but I figured it would be better than it was. I wiped all of the residue off and it looked 100% better. I threw it back into the drive and JRiver ripped it with no errors or retries. I'm sure if the scratch is deep enough it wouldn't help because it is not a very aggressive polish, but for the light stuff and stubborn smudges it sure does the trick. Smells like bananas to boot !!! 7
danowood 2,167 Posted April 23, 2015 Posted April 23, 2015 Good show Brian. I wonder about the differences between the lasers used on units now in comparisons to the ones when they first came out. I remember a demo done when cd's first came out. A cd was taken and a fine sand paper was run across it to put scratches in it and then played in the cd player and it played flawlessly. Even cd's that had pretty deep scratches in them played without fail. Nowadays, it doesn't take much at all for it to skip, etc. I wonder if the lasers are cheaply made and less stronger than in the good ole days? Opinions?
kve777 6,889 Posted April 23, 2015 Posted April 23, 2015 I like using a butane torch. One of those pencil things. Gotta be quick, but it really works! Uh, then there's THIS 1
danowood 2,167 Posted April 23, 2015 Posted April 23, 2015 "less stronger" as in not as strong a signal beam or Whatever the reason, the units today and for some time are more sensitive to cd's than on the onset IMO. I don't speak Anunnaki so I can't translate
zumbini 6,150 Posted April 24, 2015 Posted April 24, 2015 A CD consists of a thin aluminum or gold data layer sandwiched between 2 polycarbonate discs. Data is written as a series of pits and lands (1's and 0's) in a spiral track beginning at the center with the TOC. If the data track were laid out linearly it would be more than 3 miles long. If a CD refuses to "boot up" it's likely the lead-in track containing the table of contents has been damaged. Polishing/refilling/reflowing the polycarbonate can be effective if the data layer has not been comprimised. Pits are closer to the label side of a disc, so CDs are more likely to suffer damage on the label side of the disc. 2
dr_gallup 42 Posted April 24, 2015 Posted April 24, 2015 Quote Just thought I'd share something I tried on a whim. I have been ripping my entire CD collection again into FLAC files and noticed that the PC was having a hard time with Jackson Brown - Running On Empty. I ejected it and discovered that it had a pretty long scratch running diagonally from the center hole almost to the outer edge. I figured that there was nothing to lose, so I grabbed a microfiber cloth and some of this from the garage : I use it to take hazing and small scratches out of vehicle paint so how bad can it be, right ?? Not to go too hard against the common consensus (which is to not rub a CD in a circular motion) I put a little of the glaze on the rag and rubbed it in a circular motion until I could no longer see the scratch. Actually, it was still faintly visible from an angle but I figured it would be better than it was. I wiped all of the residue off and it looked 100% better. I threw it back into the drive and JRiver ripped it with no errors or retries. I'm sure if the scratch is deep enough it wouldn't help because it is not a very aggressive polish, but for the light stuff and stubborn smudges it sure does the trick. Smells like bananas to boot !!! Circular motion is OK according to Zappa: An' that got me just about as evil as an Eskimo boy can be... So I bent down 'n I reached down 'n I scooped down An' I gathered up a generous mitten full of the deadly... YELLOW SNOW The deadly Yellow Snow from right there where the huskies go (Over by Butzis' room) An' then I proceeded to rub it all into his beady little eyes With a vigorous circular motion Hitherto unknown to the citizens of Canarsie, But destined to take the place of THE MUD SHARK In your mythology THE VIGOROUS CIRCULAR MOTION... Here it goes, RUB IT! (HEY... HEY... HEY...)
4krow 6,639 Posted April 24, 2015 Posted April 24, 2015 I tried using a special CD polish once and as careful as I was, I ended up making very light scratches in the disc. The original idea from the seller was to make perfectly flat, the surface that the laser had to read. Looking back it sounds like just another sales product. In the case of an already damaged CD, the polishing idea is More Better. Ummm, just trying to fit in guys.
LVMAN777 352 Posted April 24, 2015 Posted April 24, 2015 "... NOVUS PLASTIC POLISHES THE PROFESSIONAL AND EXPERT CHOICE Since NOVUS first introduced NOVUS Plastic Polishes in 1973, the number of plastic products has grown tremendously. Yet, as widely used as plastic is, many people are still not sure how to care for it. This website can help. By using a few simple techniques, along with NOVUS Plastic Clean & Shine No. 1, NOVUS Fine Scratch Remover No. 2 & NOVUS Heavy Scratch Remover No. 3, you can actually add life to plastic and keep it looking new. Best of all, you don't have to be a pro to get professional results. Try our polishes and you'll see why manufacturers of plastic/acrylic products have used and recommended NOVUS Polishes for years. NOVUS has been the best kept secret for years, but the word has gotten out to millions of people that NOVUS can restore and clean your plastic/acrylic products. NOVUS Polishes have saved manufacturers and consumers millions of dollars over our 30 years in business. Don't settle for anything but the very best!..." https://www.novuspolish.com/video.html https://www.novuspolish.com/
LVMAN777 352 Posted April 24, 2015 Posted April 24, 2015 I bought Novis for polishing the dust cover/lid on my Technics DD Linear TT 1
4krow 6,639 Posted April 24, 2015 Posted April 24, 2015 Lyman, I am supposing that it worked on the TT cover. The question that I might have is about the many different plastics and how they would respond to a polish.
zumbini 6,150 Posted April 24, 2015 Posted April 24, 2015 Quote "... NOVUS PLASTIC POLISHES THE PROFESSIONAL AND EXPERT CHOICE Since NOVUS first introduced NOVUS Plastic Polishes in 1973, the number of plastic products has grown tremendously. Yet, as widely used as plastic is, many people are still not sure how to care for it. This website can help. By using a few simple techniques, along with NOVUS Plastic Clean & Shine No. 1, NOVUS Fine Scratch Remover No. 2 & NOVUS Heavy Scratch Remover No. 3, you can actually add life to plastic and keep it looking new. Best of all, you don't have to be a pro to get professional results. Try our polishes and you'll see why manufacturers of plastic/acrylic products have used and recommended NOVUS Polishes for years. NOVUS has been the best kept secret for years, but the word has gotten out to millions of people that NOVUS can restore and clean your plastic/acrylic products. NOVUS Polishes have saved manufacturers and consumers millions of dollars over our 30 years in business. Don't settle for anything but the very best!..." https://www.novuspolish.com/video.html https://www.novuspolish.com/ I haven't tried Novus on CD's but it's great for nasty turntable dust covers and badly scratched M-500 meter acrylic. Removing deep scratches takes a lot of effort though so I recommend using a low or variable speed orbital buffer. 1
LVMAN777 352 Posted April 25, 2015 Posted April 25, 2015 HERE ARE JUST A FEW USES FOR NOVUS POLISH DVD's, Video Games, CD's Auto Headlamps, Interiors, Gauges, Chrome, & Acrylic Paints Microwave Oven Doors, Decorator Acrylic Refrigerator Panels Motorcycle Windscreens, Visors, Fairings & Helmets Snowmobile Windshields, Helmets, & Hoods Acrylic Hot Tubs & Spas Boat Windows & Fiberglass Salad Bar Sneeze Guards Emergency Vehicle Light Bar Lens Covers Plastic Storm Windows & Skylights Collapsible Windows on Convertibles & Sport Utility Vehicles Turntable Dust Covers, Stereo Faceplates Acrylic, Fiberglass or Cultured Marble Tubs, Showers & Counters Acrylic Aquariums Telephones, Pagers, Scanners Acrylic Trophies & Awards Plastic Display Cases & Signs Gauges & Instrument Control Panels Safety shields & Goggles Airplane Windows Video Games, Pinball Machines & Jukeboxes Copiers and Fax Machines Acrylic Furniture Cash Registers & Calculators Acrylic on Tanning Beds https://www.novuspolish.com/uses.html
Sagamore2007 71 Posted April 25, 2015 Posted April 25, 2015 Thanks Lyman for the link to the Novus product. I have been looking for a product to try to clean up a Pioneer TT dust cover. I'm also curious to see how it may work on some window panels on my Wife's Jeep.
dennismiller55 4,817 Posted April 25, 2015 Posted April 25, 2015 Quote Thanks Lyman for the link to the Novus product. I have been looking for a product to try to clean up a Pioneer TT dust cover. I'm also curious to see how it may work on some window panels on my Wife's Jeep. Be careful if you use a variable speed orbital buffer as recommended by Zumbini. Friction heat does nasty things to a TT cover. How do I know you ask? I just do. 2
Nahash5150 10,775 Posted April 25, 2015 Posted April 25, 2015 I use a buffing wheel on my bench grinder. It works great! I've revived many CDs and DVDs from toddler treatment. Just gotta be gentle and buff inside to outside...
dennismiller55 4,817 Posted April 25, 2015 Posted April 25, 2015 I use this: JFJ Easy Pro DVD/CD Cleaner. I have had it for at least 3 years. Does a beautiful job. I bought over a 1000 CD's on Craig's list that did not come in cases. They were in bad shape. Some were saved by this machine if all the damage was on the non print side. If the damage is on the print side there is no hope.
