SteveFord 1,156 Posted March 5, 2011 Posted March 5, 2011 Some of this won't apply, obviously. I'm going to run this on a bunch of different sites for 30 days (end date 4/5/11) and then will tally and post the results.This uses a simple sliding scale from 1-5 with 1=sucks 2=poor 3=good 4=really good 5=exceptional.Please cut and past these questions into your reply.Thanks and please vote honestly and only once!How do you rate your: Overall Speaker Performance Overall Speaker Quality Value For Money Reliability Factory Technical Support Factory Service Ease of Doing Business With Your Dealer Ease of Doing Business With the Manufacturer Distribution Network Dealer Knowledge Technical Innovation Product Availability Brand Currently Owned: Next Speaker Purchase:
RichP714 3,181 Posted March 5, 2011 Posted March 5, 2011 and what about planar-magnetic (Carver ALS)?
OBI56 23 Posted March 5, 2011 Posted March 5, 2011 Overall Speaker Performance 5 Overall Speaker Quality 5 Value For Money 5 Reliability 5 Factory Technical Support 5 (a small plastic shaving inside the power connector dignosed within 60 seconds over the phone) Factory Service Ease of Doing Business With Your Dealer 5 Ease of Doing Business With the Manufacturer Distribution Network Dealer Knowledge 5 Technical Innovation 5 Product Availability 5 Brand Currently Owned: Martin Logan Source Next Speaker Purchase: Why would I buy another speaker?
peck555 367 Posted March 5, 2011 Posted March 5, 2011 Overall Speaker Performance 5 Overall Speaker Quality 5 Value For Money 5 Reliability 5 Factory Technical Support Factory Service Ease of Doing Business With Your Dealer 4 Ease of Doing Business With the Manufacturer Distribution Network Dealer Knowledge 5 Technical Innovation 5 Product Availability 3 Brand Currently Owned:Magnepan Next Speaker Purchase: better Maggies!!
SteveFord 1,156 Posted March 5, 2011 Author Posted March 5, 2011 Yes, I would consider the Carver and Sunfire speakers to be part of the group.
TNRabbit 371 Posted March 5, 2011 Posted March 5, 2011 Overall Speaker Performance: 4.7 Stock woofers & the extreme low frequncies are very small cons among a host of pros. They image like no other ALS speaker. Also deducted a couple of minor points for difficulty to drive well, which is not uncommon amongst high end speakers costing MANY times more Overall Speaker Quality 4 Could have slent a few bucks more here & there, but then they would have cost more, so... Value For Money: 5 Reliability: 4.5 Factory Technical Support: N/A Carver was defunct when I bought them.... Factory Service: 0 ! Ease of Doing Business With Your Dealer: N/A .... Ease of Doing Business With the Manufacturer: N/A Distribution Network: N/A Dealer Knowledge: N/A Technical Innovation: 4.8 Only because Martin Logan had a VERY similar design first Product Availability: 2 ??? Brand Currently Owned: Carver AL-III Next Speaker Purchase: ?
Audioquest 8 Posted March 5, 2011 Posted March 5, 2011 Overall Speaker Performance - 4.5 (never seen a 5 unless cost-no-object but even those aren't perfect) - For anywhere near the money, better than any of the several electrostat or planar's I've owned. The ALS-Plat was probably close or as good just in a different way Overall Speaker Quality - 4.5 pretty easy to drive and doesn't pose an obscene load like many Value For Money - 5 Reliability - 5 Factory Technical Support - 5+ Factory Service - N/A no issues Ease of Doing Business With Your Dealer - N/A Ease of Doing Business With the Manufacturer - 5 Distribution Network - 1 in Alberta Dealer Knowledge - N/A Technical Innovation - 4.5 Has things most E-stat's or planers don't have such as adjustable bias, low frequency adjustment, high frequency brilliance control. Panel is made of 3 separate angled plains so dispersion is wide Product Availability - N/A in Alberta Brand Currently Owned: Sound Lab DynaStat Next Speaker Purchase: too early to tell. A larger Sound Lab if 'E-stat
oldtexasdog 2,583 Posted March 6, 2011 Posted March 6, 2011 Rather low WAF but tough beans. Well this dumbs down my question about how the speaker placement is critical to the sound field
Audioquest 8 Posted March 6, 2011 Posted March 6, 2011 Rather low WAF but tough beans. Now that's what I'm talking about for my next Sound Lab's!
SteveFord 1,156 Posted March 8, 2011 Author Posted March 8, 2011 For those of you who haven't already voted, a fellow made up this great spreadsheet today so please use this: https://spreadsheets.google.com/viewform?hl=en&formkey=dFNrNFFXVjJha2N0SzRIQzZMVmc0Z3c6MQIf you've already voted, don't worry about this spreadsheet, I'll just add it in later on. Thanks Steve Ford P.S. If I had the cash I'd grab those Sound Labs!!!
sanford lindstrom 35 Posted March 8, 2011 Posted March 8, 2011 Overall Speaker Performance: 5 Overall Speaker Quality: 5 Value For Money: 5 Reliability: 5 Have owned from new for more than 10 years with no problems Factory Technical Support: Don't know, have not needed tech suppport Factory Service: Don't know, have not needed factory service Ease of Doing Business With Your Dealer: 5 Magnolia Hi Fi Seattle (bought before Best Buy acquired Magnolia Hi Fi) I have been a customer of Magnolia Hi Fi for over 35 years since I was a teen. Ease of Doing Business With the Manufacturer: Don't know, have not had to contact manufacturer Distribution Network: 5 Dealer Knowledge: 5 Dealer service was great the salesman came to my house and assisted in setting up the speakers Technical Innovation: 5 Product Availability: 5 Magnolia had them in stock Brand Currently Owned: Martin Logan ReQuests Next Speaker Purchase: Will not trade in our ReQuests unless they at some point break and cannot be serviced. Next ESL speaker purchase will be Martin Logan center channel to use with the ReQuests. Next non-ESL speaker purchase will be B & W CM1 or CM2 for another smaller listening area.
dokblues 101 Posted April 5, 2011 Posted April 5, 2011 Overall Speaker Performance 4.5 Overall Speaker Quality 4.5 Value For Money 5 Reliability 4.5 Factory Technical Support 5 Factory Service Ease of Doing Business With Your Dealer Ease of Doing Business With the Manufacturer 5 Distribution Network Dealer Knowledge Technical Innovation 4 Product Availability 5 Brand Currently Owned: Magnepan Next Speaker Purchase: Bigger Maggies or Sound Labs
DaveStL 85 Posted April 5, 2011 Posted April 5, 2011 Looks like I didn't resond on Planar Asylum, so-- Overall Speaker Performance 4.5 Overall Speaker Quality 4.5 Value For Money 5 (bought used, for a song; even new ones are a comparative bargain at their performance level) Reliability 4 (adhesive deteriorates; ribbons surprisingly robust)Factory Technical Support 5Factory Service N/AEase of Doing Business With Your Dealer 1 (closest dealer is 2 hrs away by car; more dealers than Pass, though!)Ease of Doing Business With the Manufacturer 4 (nice folks, only available by phone when I dealt w/ them) Distribution Network 2Dealer Knowledge N/ATechnical Innovation 4Product Availability 2 (b/c no local dealer) Brand Currently Owned: Magnepan MG-IIIaNext Speaker Purchase: Magnepan MG20.x
