Overview
About This Sound Room
Announcements, special offers, and discussion about fine products for audio enthusiasts made by Ten Octave Audio.
Welcome from fxbill and iamjohngalt!
- What's new in this room
yitatee joined the room
stereo_dog joined the room
Will Meyer joined the room
itchitch joined the room
BobTFM35 joined the room
halfbaked joined the room
Ar9Jim joined the room
philsouthus joined the room
andyheckl joined the room
peck555 joined the room
xavionics joined the room
Daddyjt joined the room
For those of you who have asked about the possibility of a demo or "traveling" LP-1R preamp with remote...we now have one available for anyone who wants to try one out! I need to start a list of those who are interested in auditioning one of them in their own home environment. You will need to pay only shipping to you from either us or the last person who tries it and you will be allowed to try out the unit with your own equipment for a week (unless prior arrangements are made) at which point it will need to be repacked in it's shipping box and sent to the next person on the list... or if there is none, back to us. If you are interested please add you name in this post so that we can get an idea of how many might be interested. The unit will be our standard LP-1R with IR remote included. The remote itself is a simple one....on-off and volume. The remote will work at extreme angles...almost a full 90 degrees to either side or up down to the unit. Please reply to the thread below if you are interested and we will begin to make a list.
Due to unforseen circumstances the kit build for CarverFest 2019 will not take place. For details on the loaner demo LP-1 with remote please see this post Since there is not a kit build being planned for CarverFest 2019, fxbill and I have been discussing offering a kit of our Ten Octave Audio LP-1 tube preamplifier at the CarverFest in September if there is enough interest. We can put together a kit of the standard LP-1 that should be built with basic soldering and mechanical skills in less than 2 days. We would provide the silk-screened steel chassis, silk-screened anodized aluminum faceplate, pcb, top grade tubes, hardware(screws/nuts/washers), electronic components, switches, controls, solder, all other parts needed, a shipping box, and instructions. We would also be on site for 3 days to provide build assistance. The price of the basic LP-1 kit (available for CarverFest only) would be $699.99. (Retail is $999.99.) We are not selling kits except for Carverfest. We may be able to also offer an LP-1R kit which would include a remote control (power and volume control.) We have a working prototype of the LP-1 with remote but we can't guarantee the availability of the remote kit for CarverFest yet. If we can make it available the price for the LP-1 remote kit will be $799.99. (Retail will be $1,199.99.) We would need 50% of price prepaid by July 10 and balance due by August 15, in order to get all parts ordered, assembled into kits, and delivered on time to CarverFest. If you are serious about wanting to build your own Ten Octave Audio LP-1 Tube Preamplifier at CarverFest 2019 please respond at: as soon as possible. Hope to see you at CarverFest 2019
4krow joined the room
@DaddyJT "Can you share the impedance of the volume pot? Remote volume is a deal-breaker for me, and curious of the possibility of modding it..." × Hi.... We use the ALPs 20K although we have also used a 100K with good results as well, although the 100K is a bit more sensitive at the bottom end and the 20K seems a bit more linear...no difference in sound though...only in the volume settings for the unit. We already have a remote kit that can easily be added to the unit and quite possibly our next model will include it, but the power transformer I had custom built for this unit already has extra taps at 6v, 9v and 12v for adding any options that might be needed. The remote we found has power on and off, mute and volume. It already has the motorized ALPs pot on it and it fits perfectly into our face plate. It requires 5 volts to run it and the 6 volt tap from our transformer will work perfectly since the remote board already has a 7805 5 volt regulator built in. The only thing that needs to be changed aside from the volume control is the main power switch that we have. It needs to be changed to a momentary switch instead of a latching switch. Fortunately we planned ahead on this and the switch we use is already available in both latching and momentary. Change that out and add the remote kit and one power relay which is controlled by the remote board (the relay costs less than $10) and there you have it. Easy squeezy. I'd estimate several hours to do the complete changeover.
HappyTrails joined the room
More rave reviews: member in Illinois, "Sounds great.. Have the factory 12AX7s in the 350s and its very nice. Enjoying the hell out of it!" member in Arizona, "I installed it in a test system and it sounds great." Thanks to everyone for all your kind words. If anyone has questions post them here or if you prefer send me a private message. David
Because of the delays we experienced with some parts and shipping boxes our initial sales got off to a rather late start...half way through the 1 month sale originally planned. I have convinced JG to extend the sale for another 2 weeks....until the 15th of April to make up for the 2 weeks of lost time at the beginning of the sale. Either JG or I can be contacted for more information. Thank you for the support we have so far received! FXB
- 1 reply
- 1
The Alps pot you're looking for is the 27mm Size Metal Shaft Type RK271 Series ALPS and is available in many resistance values. We have used both the 20K and 100K and had excellent results with either. Do not order the stepped fixed resistor ladder type that you can get on eBay for about $6. The steps were too wide apart for our purposes and it was not always possible to get the exact volume that we wanted with it. One step might be too low and the next step would jump to being too high. It might work just fine for your use though. The ones we use cost about $10-$15 on eBay and there are only a few sellers in the US who stock them. Most sellers have the cheaper stepped units. They look very much alike, but the stepped units usually have a fixed loudness tap on them giving them 4 terminals for each section. They're still quality pots, but lack the flexibility of the infinitely variable Alps which only has the normal 3 terminals per section. There are also fake ones out there that are not truly made in Japan. Check feedback on whoever you purchase one from! We order ours directly from the manufacturer to ensure that we have the real deal. We do have some stepped units here that we originally purchased since I normally like fixed resistor "ladder" typed volume controls. We can sell you one at cost if you think you'd like to try one. It might be fine for your purposes.
Sweet offer indeed not a chance un hell here but no doubt some will nab some up! Not enough exp here with tubes to comment anyhow with any degree of authority. (rarely ever had a chance to deal with such since I was a kid and that was looong ago) That said q,,, what model of Alps r u using? looks like i need to build anuber basic preamp aka volume only here for a friend with budget of near zero (higher than mine still! lol).. figure might as well inquire as it might be a viable idea.
Shalimar joined the room
I think you'll find that the silver anode 6N2's are going to sound as good or better than any 12AX7 you can sub in it, but I'll be very interested in hearing what your experiences are! They have a lower floor noise and lower microphonics of most 12AX7's and are rated at up to 10K hrs of use. The bottom end is also supposed to be better as well. The single 6N1 can be directly subbed with a 6DJ8. We tried several brands including Bugle Boys and the 6N1 sounded better...( to us anyway). Interesting thread here...... https://www.diyaudio.com/forums/tubes-valves/65548-6922-vs-6n1p-bass-response.html
kve777 joined the room
The C-1 is excellent, has lots of features, I have a c-1 as backup. I find I never use SH as I have Polk SDA’s and almost never have used tone controls. The ten Octave unit is Bare bones, which is why I like it. You need to consider if you run vinyl a phono stage will be needed. I am enjoying my Ten Octave very well, it’s a superbly made, well crafted instrument! barry
drmarka joined the room
madmike46 joined the room
BarryG joined the room
